Noticeable idle
aspen77rt
Shelton, WA
Yes, much better, that's a chebby cam as they say.
Edelbrock 7102 Chevy SB
Advertised Duration (Int/Exh): 308/318
Duration @ .050 (Int/Exh): 234/244
Gross Valve Lift (Int/Exh): .488/.510
LSA/ICL: 112/107
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2500-6500
Edelbrcok 7177 Mopar SB (The one you posted)
LSA/ICL: 112/107
See any difference in the edelbrock cams?
Lunati Voodoo Chevy SB
Advertised Duration (Int/Exh): 284/292
Duration @ .050 (Int/Exh): 241/249
Gross Valve Lift (Int/Exh): .525/.546
LSA/ICL: 110/106
RPM Range: 2500-6600
Lunati Voodoo Mopar SB
Duration @ .050 (Int/Exh): 242/252
Gross Valve Lift (Int/Exh): .533/.552
LSA/ICL: 110/106
See the difference in the mopar and chevy lunati cams? There is a reason for that.
Aspen79
LSA/ICL: 112/107
LSA/ICL: 112/107
LSA/ICL: 110/106
LSA/ICL: 110/106
Ok I feel stupid... So I see the number differance but what does it mean exactly
compubert
Florida
That article was great, explained a lot that THOUGHT I knew but I wanted to ask if this cam to lifter size applies to the slant six as well?
aspen77rt
Shelton, WA
'79 I'm no expert but to my small mind, Ramp rate, velocity more power.
Read the article. I'm not an expert by any means, but I read a lot.
You are cheating yourself with that edelbrock cam. A mopar off the shelf (OTS) grind would be better, but your still leaving stuff on the table. A custom cam ground to your full combo would take the best advantage. Also dont forget a custom torque converter as an option. Again better than something OTS. Look up http://dynamicconverters.com/.
or example, if your lifter's diameter is comparable to that of a 55-gallon drum, it's not hard to imagine a monster camshaft lobe which could lift it a foot or more off the ground. On the other hand, if the lifter is the diameter of a pencil eraser, a similarly matched cam under it would be able to move it only a fraction of an inch without it binding on the lifter edges. These are extremes, but it doesn't take a huge difference in lifter diameter to make a significant difference in the velocity designed into a cam lobe. Mopar engines had relatively large 0.904-inch-diameter lifters from the factory, while Chevy small-blocks came with puny 0.842-inch lifters. So who cares about the size of a Chevy lifter? We hate to say it, but cam grinders do. Typical aftermarket cam lobes are designed to work with a Chevy-sized minimum tappet diameter of 0.842 inch, since a lobe designed for the smallest lifter will work in any engine with a lifter that size or larger. These lobe designs are transferred to masters on cam grinding machines, and the lobe is duplicated onto cam blanks, be it a Ford, a Chevy, a Mopar or an International. Sure, these "Chevy" lobes work well and make horsepower, but the potential advantage of the larger Mopar lifter is left untapped.
cumpubert: I have no exp with the leaning tower of power. Might want to try slantsix.org.
