For engine removal bolts (I’m not sure if 5/16” or 3/8” bolts) I would use 2 inch long grade 8 (gold in color) bolts and get some big washers along with them. Washer strength is not a big matter.
When working with chain, there is a lot of “link” to get a bolt through.
On the engine stand, bolts needs to be about 1/2” longer than engine stand attachment.
If bolts are too long, then use washers to space out (or a large nut or something).
You are not torqueing the engine to the stand – so what use is not a biggie, as long as you are not using Chinese made grade 2 bolts (that break when looked at). You can tell those because they have 2 letters printed on the head (like “AE” for example).
The only thing “automotive related” that grade 2 bolts are used for is for ballast, for making terrorist bombs (I suspect – no actual knowledge known here) or to make flat tires.
