Best 8 3/4 rear replacement years
MARCH374
Need to replace my 8.25 rear axle in my 1979 Aspen .,What year's should i look in the 8 3/4 to replace it.
I think i remember the 68-70 B body ?
'66 was the starting year. You're going to have a hard time finding one and when you do you'll be paying through the nose though. Not like what it was even ten years ago. What's your build and the intended usage? If your 8.25" can't cut it I would seriously think about brand X axles.
Think you’re about right on the years. What guys ask for a used and abused 8.75 pumpkin near me would have me looking at 8.8 or 9” myself. I spent a good deal more than I needed buying and rebuilding my 8.25 than if I had went Brand X.
I half jokingly tell my wife I could build 2.5 brand X for what I have in and will end up having into my car, lol.
MARCH374
Took the car out for the 1st time after buying it in
2019. The tire's that old owner had on the rears were 295/50 .255/50 in front. Took to my mechanic to change oil, filters etc. I also has new 225/70 tire's installed. When i drove car sounds like the rear making loud noise(humming, grinding). Bringing car back to have rear end checked, brakes checked. My luck it never turns
out to be something simple to fix. Hoping for the best expecting the worst. The car is 1979 Aspen
E58 360 Police Car. Just to have as a nice driver.
Thanks
If you need one sooner than later, then you're better off with a junkyard Ford Ranger 8.8 with new perches welded on.
Or you could wait to find another 8 1/4 or 8 3/4. The deals are out there. It just takes time.
Is the housing bad? Just have it rebuilt. Unless you're looking to upgrade to get rear disc out of the deal.
8 1/4 are pretty strong. Its probably a bearing causing the noise if it's not something simpler.
