Gear Vendors Overdrive
dodgeman316
Has anyone installed a GV overdrive on a 727 in an Aspen or Volare?
I am wondering how much you would have to massage the floor to get it to fit.
I believe it would depend on how low your vehicle sits in the rear.…
Not into an F-body, but into an A-body it was a piece of cake, on a 4-post lift.
What I did was to lower the tail and install the unit, then with a jack, I cranked it up into the tunnel hard. This made witness marks in the tunnel, so I knew exactly where she wanted clearance. Then I just took the unit down, and with my ball-peen hammer, I made a little cup-type clearance bubble in two places, IIRC. Then I reinstalled the GV with two bolts as before, and repeated the procedure. After just two tries, it was in there as high as it would ever go, which was not quite enough. I got the rest by lowering the the rear trans mount. I used a polyurethane mount and all it needed was .25 inch clearance from tunnel to unit.
My Barracuda is lowered quite a bit, so I did have a minor but aggravating driveshaft vibration that I traced to the driveshaft angles. When I narrowed my rearend for bigger tires, I solved that.
My car is a 4-speed, but all in all, the GVod was one of the best modifications I did to my car.
If I was an automatic guy;
I would have installed something like an A500/A518 overdrive with a lock-up and a modest stall.
I had a GV installed behind a big block in a B body. The installation was as described by the other poster.
The unit works well although I really only use it as an OD.
A 46RH will require removal of a floor pan stiffening structure and a custom trans mount. These have been detailed in another thread. They will also require control switches to operate the OD and TTC. These are fairly straightforward. A 46RH might be cheaper than a GV if the engine is an LA or magnum block. The 46RH will need the proper torque converter for the engine to ensure proper balance. My f body has this and it also works.
Ehrenberg at Mopar Action once noted the GV unit is essentially cantilevered off the rear of the transmission. Not good.
Find a good or rebuilt 42RH and bolt her in. Make sure to run an external cooler in series with the tank cooler, and use ATF+4 (mandatory).
The 42RH is an A999 plus overdrive. More than sufficient in a street car.
