1976 Wiring Diagrams
bremereric
FMJ Body Moderator
Jackson Missouri
Here are some scanned 1976 wiring diagrams...I checked these against my 1977 Aspen and they were indentical...save them to your computer so you can zoom them and actually use them or print them out..
Thanks, but I dont know what to use to zoom with.. in any of my programs, (paint or media viewer) when you zoom you lose all resolution, so wire colors (if they are listed) becomes completely unreadable. A pdf file would probably be a better choice. And I believe you could 'bundle' them into 1 d/l able file.. Ok now to try to read some of these colors...:)
Do not want to offend any "purists" but this is a pretty easy update to HEI ign for almost anything that uses electronic ignition (points, optical, standard MOPAR electronic ign) and uses a reliable ignition module that is available over the counter just about anywhere-and cheaply. This in part from www.slantsix.org forums too.. I have found LOTS of good info there, enough to merit my membership!
