WANTED 1978 360 emission parts
willyd
Colorado
I have a 1978 Super Coupe. At some point, all of the emission parts were removed. Unfortunately, I need to replace it. Hoping that maybe someone did a delete, and has everything. Thanks
XfbodyX
Central US
I have everything youd need, even tail pipe sniffer to test with. How soon ya wanting to do it, im probably 3.5 hours from you.
Are you wanting to try with your carb or a T quad and swap it all back off after smogged?
willyd
Colorado
I’m not in a mad rush, but I’d like to get started fairly soon. I’d like to stick with the AFB carb. It’s going to be a project. It’s been converted to a serpentine belt system, so I’ll probably need to design a bracket for the air pump, or try to find all of the original brackets. The only smog part left on it is the vapor canister. This is now and this is the under hood decal, so I’m missing everything. I’ll probably need to go to an egr manifold. Colorado Has turned in to California-East. They’re pretty picky.
XfbodyX
Central US
You dont need to make anything, just bolt stuff on from a parts motor/car. Its not that big of a project.
Are you going to keep it smogged or just want it to pass one time a year?
willyd
Colorado
XfbodyX. I should be able to get 5 year tags, so I'll probably delete the system after testing, and keep it for next time. I'd be interested in what you have, including the tail pipe sniffer. How much shipped, and what all would be included?
XfbodyX
Central US
Unfortunately I went to see what was on or in the parts rig that had all the smog junk and it looks like my nephew striped and trashed all we would never use. Along with the AC stuff I wanted off it as well. Oh well, what can ya do.
I might still have the manifolds and metal air pump lines in the shop, if I do that would be the extent of it all.
welldgeo
New Member
Hemingford NE
If you're still looking got a setup for an '80 Mirada here in Western NE I'd part with. Let me get some pics for you and see if it'll work.
XfbodyX
Central US
Hey. if your gonna run a 5 year tag and swap things around, you might consider just finding the lean burn parts and it and run on the smog station. I was looking at your underhood pic, you need ALL of the cali smog junk, it would be so much easier to LB it and move on, just a thought.
Do you still have the sticker under the hood about the 4k altitude, emissions, ect. You could almost get a waiver on that.
