FOR SALE 1980 Cordoba LS E58 car
tim berry
boston area
more photos
tim berry
boston area
PARTS LIST
INTERIOR PARTS
1) dash vents - used
2) right side A pillar molding - used
3) interior belt moldings R/L- NOS these are (supposedly early ones ,they are wrapped in red vinyl)
4) exterior belt molding R/L?- NOS I do not know what side part no. will tell you
5) Mirada headlight bezels - NOS
6) Cordoba LS headlight bezels - used some pitting the ones on the car are better
7) 4 wheel turbine wheel covers with 300 emblems - used, these are in real nice shape no curb rash
8) fuel line from pump to thermoquad - used , this came off the car
9) positive battery cable NOS
10) rear bumper nerf strip NOS
11) exhaust heat shield / chimney used , came off car not rotted out
12) rear wheel arch moldings R/L NOS
13) original distributor ,leanburn
14) washer reservoir used came off this car
15) 1 chrome wheel center - NOS for cast road wheels
16) 2 thermogaurde battery cases- used both has issues but usable , one of them came off car
17) small brake booster - remanufactured , allows the use of Mopar performance valve covers
18) A/C compressor - used , original came off car
19) right door weather strip ( external,mounts to body) -NOS
20) driverside remote mirror - NOS
21) door hinges R/L upper and lower- used , need rebuilding
22) left B pillar molding - used
23) new exterior door handles R/L - NOS
24) original fuel pump - used , came off car
25) air cleaner - used , came off car missing the spark control
26) Thermoquad - used ,original to car
27) 2 seed wiper switch - NOS
28) fuel sending unit - reproduction , this unit has the correct plug
29 quarter glass weather striping 2R/1L -NOS
30) quarter glass weather strips - used bottoms R/L
31) transmission/ converter - used , original to car
32) rear quarter red side marker lens/bezel - NOS
33) license plate housing / back up lights - used missing chrome trim
34) engine bay wiring harness - used , this came off this car . I swapped another harness in and modified that one to eliminate the spark controller , wiring is not cut up , all factory plugs are intact
35) left inner belt molding - NOS , cream color
36) hood moldings 3 pieces - NOS
37) outer belt moldings and quarter glass weather strips R/L - new , reproduction
38) wiper fluid reservoir - used , came off car
39) wiper fluid plastic T - NOS , mounts at the cowl
40) original service manuals , wiring diagrams - used , factory chassis book, TSB book , parts numbers book
tim berry
boston area
I have not been inside this car in some time i forgot how nice over all car really is .
I think this particular car is a solid platform to restore , the car is dirty but actually still shines after hitting with the duster.
Any question or other photos that i can take i will .
presently the car is stored on jack stands and tucked in the corner , if your interested call at the listed number and we will fire it up together .
tim berry
boston area
more photos
I'd like to know about the blue dodge truck?
Troy thats the other problem ha ha
The truck is a 91 with a 318 4speed auto .
Basically the truck has been re done mechanically, the last components are engine and trans everything else is new .
The body is pretty clean , no rot , the paint needs attention because of the factory not sealing the primer before the color coat, you can pull it off
with tape .
I do have plans for it and is part of the reason for selling the Cordoba. But I would sell this also .
Yellowdart
Ontario
Your car is beautiful. Early on, you mention you are working with someone in Canada. Would this have anything to do with the rear fender extensions? just curious. By the way, I've had my 82 Cordoba, since January 23rd, 1982.
jasperjacko
Pm me about the truck and what you would consider a fair price.
tim berry
boston area
Yes
it would. there is a gentleman who makes fiberglass parts and said it's a 4 day turnaround. If it doesn't sell I'm going to bring the car north and have them made .
thanks for the compliment on the Cordoba.
tim berry
boston area
more photos this was the milage on the car when I bought it it now has 92k
Yellowdart
Ontario
Yes
Can you tell me who it is? I'm in Canada, and would like to replace my extensions .It's only a matter of time, and mine will need to be replaced. I don't want to waste my time with Replica Plastics. Thank you
tim berry
boston area
His name is Rob Johnson- showcar body parts .
If you get them done then we all benefit. He said a 4 day turnaround
