FOR SALE 1980 dodge mirada drag car
hemiman426
st.louis,mo.
1980 dodge mirada drag car.been a drag car since mid 80s,i brought this car with the intent to race,got it as a roller,but things dont always work out like that,car is back halfed,unknown chassis builder,car came out of south,raced in florida,then went to texas,stock front end with factory disc,drums rear,12 point funny car cage,removeable steering wheel,ladder bar,dana 60 ,5.13 gears,spool, aftermarket axles,weld wheels,crome wheelie bars,14x32 rear tires,removeable trans tunnel,dual batterys,big electric fuel pump,all lexan glass,fiberglass deck lid,removable fiberglass frontend,turbo action air shifter,delay box,arc overhead switch panel,rear aluminum wing,removeable fiberglass hood,400 stroker to 499,ohio crank rotating assy,indy sr heads,milidon gear drive,harland sharp roller rockers,smith bros push rods,bushed lifter bores,hard blok,indy 4150 intake,with adapter for 4500,demon 4500 carb,roller cam 715 lift,msd distributor,msd coil,msd wires,msd 7al box,b&m flex plate,8" convertor,old school jvx transbrake trans,chassis was certify years ago,trans blanket,has motor plate and mid plate,i have not raced or test and tune this car,dont have the money to,or will sell as roller for 6k,car has a vin but no title,runs on race gas,has battery cut off and charging lugs ,no rust,80s paint and decals,would make great nostalgia car,or bracket car,has kinda of a paul rossi paint on it,contact hemiman4262003@yahoo.com,12000.00 obo
MiradaMegacab
Long Island NY
The OP hasn’t been on since Nov 13 2017.
I believe he’s an active member of FABO or FBBO...
MoparMike, what’s your location?
MiradaMegacab
Long Island NY
Well as being that the OP hasn’t been online for over a year...
I’d to sell a caged roller with a ford 9”, 4 link Mirada...
Too bad you’re so far away...
