1980ish Mirada build
MiradaMegacab
Long Island NY
Hey can you post exactly what parts and part numbers you bought? I'd love to hear more details about what you did. Been thinking about this too. Thanks!
I don't have access to the part#'s. I tried looking on Diamond Pistons website but had no luck. I used their 2618 forged piston 4.030 with a -30cc dish and 1.55 compression height. Diamond charges $8 per piston to relocate the valve reliefs. The 2616 forging and deep -30cc dish is perfect for boost and results in a 8.5CR. I'm running a 65cc head and 10PSI of boost.
I figured a 3.79 stroke divided by 2= 1.895 + 6.125 rod= 8.02- 9.58 deck height= 1.56 compression height, resulting in the pistons being .010 in the hole.
So pretty much if your using a 3.79 crank, look for a piston with around a 1.56CH.
Using a 6.123 it a longer 6.125 K1 rod will get your deck height close.
Shorty Thompson
Taylorville, Illinois
The Silvolite 1278 pistons are flattops . Not to mention that since I'm milling them , they'd be flats anyway. I,,,,,,,, talked alot to my machinist about 50 - 150 shot of NOS . He said WHOA ! Your heading way ,,,,,,,,,into another direction with that , and I'm not gonna lead you down the wrong way to build for this . If ya wanna do that , then we need to recoup and do things way ,,,,,,,, differently . So ,,,,, I'll be happy with the compression ratio of about 9:2 . My heads are stock 340/360 high performance ( supposedly ) for this build . Stock rods , 6.125 , 360 rods . Now I have a set of 5.9 magnum heads , but I still have the magnum they're bolted to as well . Time will tell this summer as to where I'm at .
Shorty Thompson
Update on my motor build, My piston location ;
getPart
Shorty Thompson
Sweet. I just happen to think about it and wondered how it was coming.
Well thanks for remembering ! Son's got the Mirada now. Gave it to him with provisions. 1. if ever decided to get rid of it he had to pay " in full " for it . 2. it had to go to my grand daughter , his oldest , then to his son , the youngest. Right mow he's looking at a 5.9 Magnum build . I'm thinking he's doing a 408 build.
