1982 Chrysler 5th Ave left front window is jumpy and requires assistance to raise? Any window pros here?Mike
493mike
New Member
midMichigan
Left front window is jumpy and requires assistance to raise? Any window pros here?
Mike
69-
Germany
Likely the carbon brush inside the motor.
They are available and exchange is not to hard, once you got the motor out.
Did that myself on a 79 LeBaron.
If the spring is broke, use half of a pencils spring.
The common cause is the gear or bushings in the motor end but lately it seems that some people are having problems with the roller on the metal arm that makes it go up and down.
493mike
New Member
midMichigan
It had a worn out clutch so I just purchased a new motor assembly from Rock Auto as it was not much more than a new clutch assembly.
Mike
armataz
springfield OR.
Mike
possibly gunk build up.if motoized clean the motoy withelectric parts cleaned/lube.just sptay it out really good and seeif it helps, it is non flamible.
nightman61
Memphis, TN
Mike
I had the issue on my 80 diplomat, 2dr. Went to rockauto and they had the internal gear for the window motor. I replaced this and took care of the issue. Good spare part to get now.
Ele115
Tampa FL
9/16" Nylon rod cut into 3 little rollers and some grease
Mr C
My bet is that you lost a plastic puck in the gear head...so you have 2 instead of 3 making it jump.
69-
Germany
We're all excited to hear which of the list of possibilities made it.
And good luck with the repair.
armataz
springfield OR.
I also like to hit the window frame tracks wits spray silicon to help the windows slide in the tracks easier, and condition help soften the guides
