1985 Gran Fury - Decatur AL - SOLD
‘85 Gran Fury in Decatur AL
90k miles
$5,000k
Clean, Gran Fury; Cowboys vanity plate aside.
Not my car, no affiliation.
Full FB ad: 1985 Plymouth gran fury
Looks really clean, any more info about it?
Odometer reads 43K miles which matches readings on Carfax for the vehicle up to 2021. I assume that's the correct mileage. It was listed to have 90K but the guy said the previous owner said add 50K but the guys says he may have been of questionable memory. Who knows. It seems legit, but I went into the deal assuming 90K miles.
Car cranks right away with no stalling, etc. It does have some rough idle at times and has no passing gear to speak of. However, from what I read on here, that is to be expected with the factory lean burn in place. It has 205 tires which are the minimum rated size on the door sticker, but I think some taller ones would make the car look better. Also maybe the full wheel covers vs. the turbine ones now. I'm not a big fan of the turbine.
Edited to add under carriage photos.
Update....I tend to believe it really is 43K miles as the tires still have great tread and are date codes HBH1115 and HBH1215, making them 9 year old tires! They are pictured here in 2018 much newer....
Excellent!!!!!! How exciting! Get a set of police poverty caps on that and it'll look mean!
Nah, don’t do, dog dish caps. hold out and find a nice set of Chrysler Snow Flake wheels. They really pull these cars together.
Is this oil something major (under compressor...valve covers not so concerned with)? It is wet there and shiny.
Looks like weeping build up over years from the pictures. old cork valve cover/intake gaskets probably about due for a replacement.
Mine had a ton of gunk under the compressor and on top of the intake. It was a very slow leaking upper radiator hose. I moved the clamp and retighten it. I had to replace a chunk of heater hose too now that I think about it
Looks real good, that’s about as clean as you’ll find anywhere. What’s the plans, Gen3 hemi swap?
