255/60-15 tires
bbeep71
Will these 255/60-15 tires fit on 87 5th. Can I use stock rims or need something larger? The 5th has 205/75-15 on it now.
Thanks
stock rims come in more than one width. I have run that size on the rear using 7" wide cop car wheels. Most mopar alloy wheels and some steel "road" wheels of the era were the same width.
I've had 255/60s on 7" steel wheels cleared with no issues on a F & J body. Also, 275/50s on Mirada 10 spoke wheels without any issues either.
I have 255-60-15 rear and 235-60-15 front on 7" rims on Modoba. Probably as big as I would go on a 7" rim. You could go bigger, but will likely have uneven wear issues. m2c
