2bbl carb base gaskets...which one?
Engines, Exhaust and Fuel Systems
  1. TylerW
    TylerW Member
    21
    Jan 5, 2019
    Southern Middle Tennessee
    Hey guys:
    Each time I obtain a 2280/BBD kit, there are 3 base gaskets- 1 thin 2-hole type, 1 thin open type and one thick open type.
    Which came factory original on a 318?
    As you know, the distance of the carb above the intake ends up affecting the choke adjustment, and the trans rod geometry to a lesser extent . Thanks.
  2. volare 77
    volare 77 Well-Known Member
    884
    101
    Jun 12, 2014
    For me I have always used the thick one as that was usually what came off. What was previously on there?
  3. volare 77
    884
    101
    Jun 12, 2014
    I googled a 2bl kit 4049320 for 1977 318 and the pic shows a thick gasket. Mopar kits are more specific. Aftermarket kits fit multiple applications.
  4. volare 77
    884
    101
    Jun 12, 2014
  5. 89.Fifth
    89.Fifth Well-Known Member
    318
    68
    Sep 5, 2015
    New York, NY
    If you want an OEM thick gasket I probably have a couple laying around.
  6. Aspen500
    Aspen500 Well-Known Member
    3,665
    1,050
    Rib Mountain (Wausau) WI
    Original would have been a thick gasket. It's main purpose is to insulate the carb base from heat transfer, which would then transfer heat to the fuel bowl.
    I've never decided what the thin gaskets are used on, that come in the kits.
  7. TylerW
    TylerW Member
    21
    Jan 5, 2019
    Thanks everyone. I actually found a parts list for '84 Dodge trucks posted online and it indeed shows a thick insulator. I have several on hand, so I am good there.
  8. volare 77
    884
    101
    Jun 12, 2014
    Glad you got your answer.
