76 Aspen disc brakes help.
Ghostrider 67
salisbury, vt
Hi all. I am building a resto mod B body with 76 Aspen front disc brakes. my questions are; Did the Aspen have a proportioning valve?
Were there both vented and solid disc rotors?
Did the Aspen have dust shields.
Thanks,
Ghost.
The brake proportioning valve came in a few different versions – but only two vesions (that I know of) for FMJ bodies.
Those with 10” and those with 11” rear drum brakes.
In general there are a few different B-body proportioning valves – mainly depending on what year car.
The differences that I do know about are:
4-wheel drum brakes.
The early 4-piston brake calipers (and with 10” and 11” drum brake versions).
The 11” pin type brake rotors (with 10” and 11” drum brake versions) – which I “suspect” are the same as both FMJ versions (but not confirmed).
The 11¾” disk brakes (with 10” and 11” drum brake versions).
So I count at least 7 different B-body brake proportioning valves.
The only Mopars that I know of that came with solid brake rotors were front wheel drive (or were made in last 15 years – which I have not kept up with).
