SOLD 78 Volare, final part-out sale
halfafish
SW WASHINGTON
I’m clearing out the last of the parts from the 78 Volare. As things sell I will update the ad with what is sold. Otherwise if you see it, it’s available. Parts not listed are not here anymore, I sold the body a few weeks ago. Surprisingly for the rest of the car being dirty/greasy, the interior stuff is in pretty good shape. If I know anything about the parts I will list that info. I would consider anything that can be rebuilt as needing that. The car was a runner till it chewed up the timing chain, but then it sat for a number of years. All sales are final, no returns or refunds so please ask questions and check the photos carefully before making a purchase. All items are plus shipping costs. I take PP or USPS money orders. If you use PP, please either send as “friends and family” or add 3% to the item cost to cover the fees. The hood and deck lid are local pickup only, I’m not going to ship them. If you want more info or photos, let me know. I was unable to test some items to see if they work or not, if someone knows how to check them out I’m willing to do so but otherwise they should be considered a core. I have a lot of stuff to post and sell, so some patience would be appreciated to give me time to respond to questions. I will use USPS flat rate boxes for shipping where possible. This will take a few days to get everything listed, so stay tuned...
Headlight buckets in good shape, $20 for the pair. The tape is holding on whatever screws I was able to salvage.
Headlight trim rings, $20 for the pair. The passenger side was pushed out of shape a little and one screw hole was elongated by the front fender damage shown in the photo. The screw hole is still workable, and I think the ring could be massaged back into shape pretty easy.
Sun Visors, $40 for the pair. These look really good, no rips/tears and all the hardware works.
halfafish
SW WASHINGTON
More parts...
Instrument panel circuit board, $20. I have no idea what works or not. It does have one missing pin at the 1:00 position, shown in the photo.
Trunk latch and lock with a key, $10. It does work, but I had to jiggle the key up and down some to get it to turn.
Arm rests, $30 for the pair. They are in good shape with the exception of the one crack shown that is about an inch long.
halfafish
SW WASHINGTON
More parts.
Glove box door, $20. It is in good shape, the tape in the photo is just there to hold on the mounting screws.
Ash tray, $15. It was used for smoking and is rusted on the interior but otherwise it’s in good shape.
Ash tray mounting plate, $10. It’s in good shape.
halfafish
SW WASHINGTON
Listing more parts this evening.
Windshield washer reservoir, $20. It’s in good shape with no cracks or leaks. The washer pump is still attached but I didn’t get a chance to test it.
Radiator overflow bottle from a slant six engine and radiator, $20. In good shape, it was still holding liquid when I took it out.
Window cranks, $10 for the pair. I have them both but only took a photo of one? They are in good shape, the tape us just holding the screw in place.
Power steering pump mount for a slant six, $15. The tape has the part ID on it because I'm an idiot and otherwise I won't remember what it is...
halfafish
SW WASHINGTON
Brackets that hold on the front marker lights to the radiator support, $10 for the pair.
Fan for a slant six, $20.
Fan spacer for the slant six, $10.
Secondary hood latch, works fine, $15.
Remote hood latch, works, $15.
halfafish
SW WASHINGTON
Vertical bracket that holds the upper radiator support, slant six car, $15.
One piece of the transmission linkage, $5.
Wiper arm mechanism from behind the cowl, appears to be in good shape. $25.
Emergency brake pull handle, the tape is holding the mounting screw, $5.
Door sill plates, in good shape, $30 for the pair.
Bob the Builder
Curtice, Ohio
Would you happen to have the driver and passenger fresh air vent boxes or any cables going to them. Just any parts to them I may take. I need cables and the damper plate in the vent bow is broken. Thanks for your time. Bob
halfafish
SW WASHINGTON
More items to list today.
Support rods that go from the firewall to the fenders, rusty but otherwise OK, $15 for the pair.
Wiper arms in good shape but the blades are shot, $15 for the pair.
Defroster vent ducting, in very good shape but it’s bulky so I imagine it will be a little expensive to ship, $20.
Heater control unit. The cables are in good shape and not kinked, no idea if the fan switch works or not. $25.
halfafish
SW WASHINGTON
And another batch.
Gas cap with a key that works. Rusty but otherwise OK, $5.
Passenger side dash panel where the glove box and ashtray mount, in good shape and includes the metal support bracket that continues across to the driver’s side of the car. $40, it’s quite bulky and probably expensive to ship.
Instrument panel bezel, in good shape with decent driver quality bright areas, $20.
Not sure what to call this one, it’s the instrument panel mounting plate, behind the dash with all the instruments removed. The PO had a cruise control attached to it, the switch is still there but I’m sure it’s no good. $20.
Headlight switch and wiper switch, not tested so no clue if they are good or not. $20.
Bob the Builder
Curtice, Ohio
Another question, do you have the splash covers on the inner fenders and the battery tray? Trying to remember what I need to restore my 77 volare roadrunner.
james legg
Chicago
Hey buddy I'll take the wiper arms oh, I actually only need the blade parts I know they said they need refills but right now I got a crappy plastic ones. But I'll take the whole mess ship to 60631 send me your PayPal info thanks
Bob the Builder
Curtice, Ohio
Just wondering if someone has bought the fresh air boxes and cables. If you sent me a PM I don't know how to retrieve it. Thanks again
