8.25 gear set up so far not being friendly
prowler
santa clara CA
Well,.....my project has appeared to hit a major snag. I'm currently trying to install 2.76 gears and new everything else into a 8.25 diff. So far I have installed and removed my gears 36 times as I cannot get a proper ring gear pattern. The 2.76 gears are difficult to get as there's not a lot of demand for that ratio. I had found one company that had one set left so I ordered them. I've had every possible combination of shim under the pinion bearing and can't bring the required pattern any where near where it's supposed to be. It would appear that the cut on the gears themselves are the only reason why the won't come in to spec. Anybody else had a similar problem??
AMC Diplomat
NY
What carrier are you using? I think there are two different carriers for the 8 1/4 based on the gears
There are 2 different carriers. IIRC, 2.76 and higher (numerically lower) uses one, and 3.23 and lower (higher number) a different carrier. Moot point in this case but 2.91, not sure which it uses.
Trying to put 2.76 on a 3.23 carrier will never work, and vice versa.
Keep in mind, the above is from a slightly fuzzy memory, so take it for what it's worth, lol.
I think the split was lower then that, that 2.76 and higher were the same. But I haven't messed with that stuff in ages.
You are correct, I was not. Checked my fuzzier than I thought memory. It's 2.54 and numerically lower use one carrier, 2.76 and numerically higher use the other.
Prowler, disregard my previous post.
prowler
santa clara CA
New Yukon carrier. Correct for ratio as well. I had bought the set up bearings so that has helped with all the set ups and tear downs. I have gone from zero shims up to 60 thou and can't move the pinion contact point off the top of the ring gear heel drive side towards the middle on the ring gear in any kind of useable pattern. I have also read about gears being a 2 cut apposed to 5 cut. I though about taking it to diff shop but as far as I'm concerned, they're going to charge me a couple hundred bucks and end up saying,... this is as close as we can get it. This isn't really a difficult job but I'm sure the outfit I got the gears from is going to insinuate that I'm doing something right and since this was the only set they had, I'm probably going to have to buy another gear package.
MARCH374
Will be following this, Have a 81 Imperial with 224 rear, Looking to change to 2.94 rear myself. Looking for a supplier myself.
prowler
santa clara CA
I have not seen any 2.94's. Most of the gear manufact's start in the 3.0 something. I had thought about the 2.94's as well but just couldn't find any !! Prices seem to float all over as well. The gears I bought were from what I'd call an off brand but I never anticipated that I'd get a set that wouldn't pattern properly.
MARCH374
That's what i am afraid of too.
That's probably a 7.25" axle if it's factory. I don't even think anyone makes gears for that axle anymore. They certainly don't make limited slip for them. 8.25" out of a wagon or AHB car is probably your only option for something that bolts in.
MARCH374
Def a 8.25 rear. Auburn Gear is checking for me, They say they have posi unit for either ratio's. Checking for ratio that i can live with now. Thanks
prowler
santa clara CA
Install gear pattern problem solved !! The whole issue was MY fault. As careful as I am, I missed one basic item. I couldn't believe it as once this was corrected my pattern came right in. As follows,....when I tore the diff apart, cleaned all compiled the parts I was going to reuse, I assembled all my new items into the housing and started having my described set up pattern problems. 40 installs and tear downs later the problem was as follows. The screwed diff bearing back lash setting cups, I had installed in the wrong direction. After all that time, I decided to refer to my factory service manual that had an exploded view on the 8.25 and there it was. The cups being reversed impeded the carrier from proper ring gear contact on the pinion gear producing errant patterns.
69-
Germany
Thanks for the update & solving the 'mystery'.
LSM360
Melbourne, Florida
Glad you got it solved! I have a set of Yukon HD gears in my AHB. I replaced the factory 2.94 gear set with Yukon 3.21 and a Mopar Sure grip. For a HD gear set it's pretty quiet and has been trouble free.
prowler
santa clara CA
Thanks for comments. Things are moving along nicely. Gone through final pinion setup/back-lash. Removed set up bearings and replaced with the install kit pressed on's. Slightly changed ring gear pattern but not enough to need pinion shim change. After much research I decided to not use crush collar set up and go with the solid sleeve/shim assembly. It required several shim changes to get pinion pre-load correct but in the end it worked perfect !! I did however need to add some shim once the actual install bearings were installed as the new front bearing must have been a few thou off from the setup bearing and changed my pinion preload measurement. Backlash measurement took a bit of adjustment(s) as lash measurements around the ring gear with 10, 8, 8, 7. Book measurements were between 6 and 10 so I called it done. Next step, axel bearings/seals, backing plate and slide axels home.
