80 Cordoba
Here's a picture of the spindles from the 80 Cordoba I parted out. Asking $100 shipped from 22657. I'll have to remove the caliper adapters to fit in the box OK (but will be included with hardware).
Here's a couple more pictures of the spindles - front of one and back side of the other then reversed
it shouldn't have a ball joint the ball joint should be mounted to the lower control arm not the steering arm.
The lower ball joint is mounted to both the spindle (steering knuckle) via the 2 bottom mounting holes and by the ball joint stud to the lower control arm. Steering arm??
