WANTED 80's Cordoba corners
FMJ Body Parts Wanted
  1. BBodyDan
    BBodyDan New Member
    Apr 14, 2018
    Contact Seller
    Looking for the corner pieces for my brothers Cordoba, they all just turned to dust pretty much i guess from the sun. Anyone have any for sale or know where he can get some? Thanks in advance.
  2. Yellowdart69
    Yellowdart69 Well-Known Member
    252
    33
    Apr 26, 2011
    Toronto, Ontario
    We all have the same issue.
  3. 4speedjim
    4speedjim Well-Known Member
    448
    74
    Aug 6, 2016
    Portland NY
    Is it VFN.com? Its them 3 initials. They do (did) the fiberglass J body replacements. They do a lot of fiberglass body parts for drag strip bodies. They're the only place I know of. They'll need a little massaging and imagination. Theyre much better than nothing, but not oem.
  4. Dr Lebaron
    Dr Lebaron Well-Known Member
    2,772
    582
    Aug 17, 2011
    Islamic State In Canada
    3D printer.
  5. Yellowdart69
    252
    33
    Apr 26, 2011
    Toronto, Ontario
    Three D printers , from what I have seen, make things out of flimsy plastic. Why do you think they would work?
  6. Yellowdart69
    252
    33
    Apr 26, 2011
    Toronto, Ontario
    Speaking to my son, who knows about 3D printing, two questions have come up. first , he would need the actual part to scan. I don't want to remove mine, to experiment with. Second, he asks what temperatures, does a car get "baked", when being painted?
  7. 4speedjim
    448
    74
    Aug 6, 2016
    Portland NY
    Its not very high. 140-150F. A dark car in the southwest sun gets that hot I believe. Powder coat bakes around 400F.
  8. 4speedjim
    448
    74
    Aug 6, 2016
    Portland NY
    yellowdart with 3D printers you can make a part as thick and solid as you want. Because its tiny dots, thick and solid is very time consuming. Print a heavy pair to use as mold forms.
  9. Yellowdart69
    252
    33
    Apr 26, 2011
    Toronto, Ontario
    The corners, I am told, could be printed out of ABS, Nylon, or poly carbonate, but at a cost of about $2000. each.
  10. 4speedjim
    448
    74
    Aug 6, 2016
    Portland NY
    So there IS options! heh heh heh
