shadango
Hey all
When I originally got the car a few years back the cruise worked....used it on the way home from the purchase even. About 38k miles on the car. Yes it is a "survivor" as they say.
But anyways....at some point sometime the cruise stopped working...I don't do a lot of highway miles with it so I haven't been too concerned.
But of course when the tinkering bug takes hold, look out...LOL
I have the service manual.....went through the items. The brake stop switch is way up under the dash and I didn't feel like breaking my back today so figured I would first move on to the easier stuff....
The cable is attached at the carb....I have a speedo so I know the two speedo cables are ok.....I turned the ignition to "on" and worked the cruise switch and can hear the servo clicking as the book says to do....I cleaned up the three wire ends and terminals at the servo anyways, they were a little crusty.
But one "easy" thing left is to check the fuse per the manual. I cant find it.....the fuse block doesnt show that, and everything listed on the block works....and I assume that the fuse is fine since the servo clicks (right?)
But can someone clue me in on which fuse in the block is the one that controls the cruise?
The service manual shows pics for "J-E-T', 'B-F-G', 'X-S', and 'Y" models.
Call me an idjut, but I cant seem to figure out what the 81 Diplomat is.....those dont match the carline codes of J, Y,, M (diplomat), H, P, S and P shown in the front of the manual. So I feel dumb.
So I am going by "F" for F body.....and that image shows cavity #2, a yellow fuse..for rear window heat, speed control and "cornering lamps".....The fuse looks fine to me....I dont have "cornering lamps" and the rear heat connectors are busted at the window...LOL..so no way to test but the fuse looks fine to me...
Plus like I said, the servo clicks when tested.
I am guessing that maybe the stop switch should be my next visit.....in the manual I bought (it didnt come with the car) someone had written the part number and cost for that very switch in the manual on that page. So I know it can be an issue obviously.
But want to rule out the fuse before i contort my aged back into a pretzel and suffer for a week afterwards....LOL
Or maybe I dont need cruise afterall....
