Bought some more garbage! Now i gotta delete it
DumpsterFire
North Carolina
Mostly deal with a bodies but just got a diplomat as a primary beater car and came over here to look at all the info on getting all the smog insanity deleted
Remow2112
I love the M body platform. Drove an 80 for years. There is a bunch of stuff you can delete if you don't have emissions to worry about.
get rid of the lean burn ignition is a good start. I believe there was an air pump and multiple cats too. If you want to stick with the 2 barrel see if someone on here still has a 76-77 Carter BBD in good shape laying around.
Mr C
I have an 84 Dippy. Awesome, very reliable daily driver.
I essentially took my car back to being a 70's set up... LB delete Mopar electronic ignition, you want the Canadian no cat Y pipe (I had to have one made...they are pretty impossible to find now), yank the air pump, if equipped. There wasn't that much vacuum line nightmare as I recall. Really cleaned up the engine bay.
I kept the 2bbl on my 318...it's fine for a lo-po driver.
DumpsterFire
North Carolina
I already got a bbd laying around for it. The cats are on their way to the garbage as we speak. Already dumping way too much time in this junk
DumpsterFire
North Carolina
Trying to find a replacement y pipe. Probably gonna have to end up making it myself
