Brake/ turn signal lights
Deano
Clarkson, KY
How do I get all six of my taillights to come on when I hit the brakes or use the turn signal instead of just the four on the inside and outside? I realize that it's the way it was designed, but I think it would look a lot better if all six would activate.
69-
Germany
IIRC the middle light is a single bulb (park only), not a dual (park + brake/flasher).
Don't have my LeBaron (79) at my house right now, so I can't look it up, but what you want would mean to change the bulb socket to a dual one and wire it accordingly (same as left/right bulb.
And I'm absolutely unsure how that socket is fixed in the tail light assy.
Perhaps I'll have a chance to take a look at mine tomorrow.
69-
Germany
Did a cool ride today with the LeBaron and took a picture - amazingly, in my trunk there's a socket for dual bulbs, but only one wire going in...
Take a look behind the plastics and you'll know what to do. The right socket is the "outer light", left socket is the middle one.
Here's my ride:
Pretty much all you need to do is, change the sockets to ones with 2 wires, and splice the brake/turn into the existing wire for each side.
