Caster Shims
Millmech
Arizona
Does anyone have dimensions of Caster Shims. If nothing else, thickness. Longer bolts needed? New bolt length?
1977 Aspen [Olga]. Wanting to get this done in 1 day. Thanks -
This thread has all you ever wanted to know about the shims and then some. Actually they're camber shims, not caster shims but I'm picking nits. Scroll down a ways and there is an illustration with all the dimensions on page 2. I did this on my car and it fixed it right up (used an NOS shim kit off Ebay). The existing bolts are more than long enough to use with the shims.
He used 1/4" steel to fabricate his own, but pretty sure the factory TSB ones are 3/16".
Alignment problems?
Can you tell I'm an auto tech? Always have to use the correct terms or I'd be drummed out of the collective, lol :)
Millmech
Arizona
Thank You. What thread is this, of which you write
Alignment problems?
Thank You. Could you direct me to this thread?
Yeah, I wasn't totally sure what thickness they were.
You must have missed the link I posted but BudW has it also. Afterall, it was his thread to begin with! lol
Click on the "Alignment Problems" at the bottom of the post and it'll take you there.
