M_Body_Coupe
500 mile break in, I've had 8 3/4 gear sets last 125 passes, about 60 miles and there missing teeth. A switch to synthetic and I pull them at 400 passes.
I use 4.88 pro gears...
...alright, but everyone knows the drag racing use is significantly different than street use. Case in point, a 1/4 mile pass stresses the mechanical & strength aspects of the gearset, the street stuff on the other hand will primarily kill the gears due to heat build-up and therefore the breakdown in the lubricating qualities of the gear lube and the subsequent metal-to-metal contact.
Were you running a SG unit, or was this a spool setup?
I honestly would not mind running synthetic being a strong believer in their advantages. The problem is that the old stuff we are using today was not designed around the tech advances we see these days.
Put another way, my '742 carrier build uses new Richmond gears as well as new SG clutch plates (and bearings, etc, etc)...so I'm really looking for a durable combination that will not need any work to stay in shape.
