Different rear sway bar diameters
imperial416
Tucson, AZ.
Have to admit I thought I'd gone crazy after someone responded there was only one size since I have two identical bars in different diameters. I just wanted to identify them so I know what they are for.
All else being the same or constant, as rear sway bar dia. increases the system tends to move from understeer or neutral toward oversteer. Drifters like the tailwagging oversteer. I've always gone for good balance or a neutral chassis even if I can only generate .98 G on the skidpad and not the braggable 1.0 G or higher. Appreciate all the responses.
Ele115
Tampa FL
All of my Cudas have the same rear sway bar, even the AAR. There are two sizes for the front. I never gave it much thought though. I had always assumed the AAR would have a different rear bar but it's not. The front it different than the others though. And it's never been apart other than the fuel lines
