Dirt Track Racing, Open or Locked Differential?
Classic Mopar Racing Forum
  1. Diplomat_Wagon
    Diplomat_Wagon Well-Known Member
    132
    Jul 3, 2012
    Saskatchewan, Canada
    The class I race in is a bone stock "Thunder" series, stock cars, stock drivetrain, stock suspension, D.O.T "P" series tires etc..
    We are allowed very few modifications and one of which is being allowed to weld the differential, no Limited slips or spools. Just a straight up welded stock diff.
    My track is 3/8 mile clay surface oval track with 80' of track width and a decent bank but nothing extreme.
    My personal opinion is that the car I run doesn't really have the power to power through the turn and a locked diff with improper tire stagger will actually hurt my performance.
    I just don't have a lot of racing experience and want to set my new car up right.
    Any dirt track guys out there?
  2. BHA43
    BHA43 Well-Known Member
    304
    27
    Mar 26, 2012
    I say weld it as you go thru the corner the weight comes off the inside rear & a open diff will spin like if you were stuck on ice thus no power to the ground!
  3. jasperjacko
    jasperjacko Well-Known Member
    1,495
    194
    Dec 4, 2011
    Is there a rule against a shorter leaf set on the drivers side to move the left end of the axle forward an inch to help it turn better. I don't know just a thought. I would also think you want 2 tires biting, but welded up might hurt turning. I'm sure there's plenty of setup to fix that though.
  4. Diplomat_Wagon
    132
    Jul 3, 2012
    I was thinking of offsetting the diff on the spring perch, since I'm eliminating the ISO setup at the back and the spring perches have three holes in them so I could offset the diff on the springs without having to modify anything since I'm not modifying anything I'm just putting it together wrong. :D
    Here is an excerpt from my rules.
  5. Mroldart2u
    Mroldart2u Well-Known Member
    262
    May 4, 2011
    Amarillo,Tx
    You will want it welded....
  6. Mroldart2u
    262
    May 4, 2011
    Amarillo,Tx
    Well D_W what did you decide?
  7. Mroldart2u
    262
    May 4, 2011
    Amarillo,Tx
    I never have figured out why they dont allow a spool, (Tracks around here are the same way) its no gain vs welding. It just does away with the spyder gears and the cross shaft.End result is exactly the same. Locked together axles...
