johnnyride
Hi all,
I have a question on an engine component. I was taking off my air cleaner assembly to get at the carb and when I went to pull off the air/breather hose you see in the picture, it pulled off the nub on the end of that gold part that goes from the air cleaner into the valve cover. Can someone identify that part, what it does (I assume air) and if the part is still available. Thanks all, sorry if it's a stupid question that I should know, but I am not good with engines.
And how can I remove it? Does it pull out, turn out? I have a Slant-6 LS parts car - I believe it has the similar part in it. Are they the same?
John
John
