Plymouth3596
Maybe some one here knows I just did a antifreeze change as well as all the hoses and thermostat on my 1987 Gran Fury 318. When running it did leak a bit and left a trail but no over heating when I shut the car a stream( pissing) on the passenger side looks like behind the K frame anti freeze pissing out in a stream straight dow to the ground then it stops I guess there's no more pressure. None of the hoses are leaking is there a drain at that location ? Maybe there to much anti freeze in it and the car is getting rid of it? What else could be leaking from there? I haven't got it up in the air to look yet thought if there's a drain there ill take some anti freeze out.
