Hello from MRL Performance
MRL Performance
Hey guys and gals.
Im Mike from MRL Performance. I would like to take the time to introduce our shop. We build HP Mopar engines, supply HP parts and provide Tech help to our fellow Mopar Maniacs. We are a Mopar only shop, tough I know, but its a passion.
90% of our business is building custom engines from /6 to Monster Big Blocks.
You can visit out web site by clicking our Banner ad to the right or by going to www.mrlperformance.com
Thanks so much for all the support!
We are located in Chesaning, Michigan and can be available 7 days a week!
Eastyorker
Welcome
I know someone who may need his slant 6 souped up. Hopefully he'll contact you.
MRL Performance
We did up a super nice one last year 250-275hp
1976RR
Mike ... just doing a couple of cosmetic things to my Dart right now ... but by end of summer ... i am DEFINATELY going to sit down and talk with you on a 500-600 hp small block!
MRL Performance
Sounds good to me. We have 2 Stroker SBM in here now. One is going to be in the 550hp range the other in the 475hp range.
Just shipped 2 BBM, 470 making 730HP/625TQ and a 505 making 650HP/TQ
That slant was around $4000 the way you see it. Trick stuff inside
greymouser7
31547 off of I-95 near I-10
So is it taboo to ask
Barring that the prices are subject to change and other disclaimers...
Bore/hone sbm/bbm with TQ plates -
Square deck sbm/bbm block -
Install cam bearings (Babbitt) -
aluminum and then iron heads:
Rough estimate prices for the following services:
head and block cleaning labor -
magnufluxing -
multi (more than the standard 3) angle valve job -
valve seat prep -
valve spring seat
Flat milling heads -
Intake manifold milling -
Install bronze valve guides -
Open intake valve seat to larger seat diameter -
intake manifold labor?
head assembly -
connecting rod balancing -
rotating assembly balancing -
and other services?
thank you for your time and service,
greymouser7 :)
Mroldart2u
Amarillo,Tx
magnufluxing -
valve seat prep -
valve spring seat
head assembly -
and other services?
greymouser7 :)
Fone call would be way easier and less time consuming, after all time is money...
MRL Performance
Im new here and am on the other FOR XX Bodies sites as well. Ill post up some stuff soon. Thanks Guys!
