Help w/ throttle /trans connections
Could someone take a good photo of the driver side of their carb ( between the carb and the valve cover). I need to see the the throttle cable routing and trans pressure linkage off the carb. I was getting some binding and I think I routed the Throttle cable wrong. I have 2 different chiltons(older ones) and it is not clear enough to see actual routing. position.
Thanks
My imp
Brunswick, Ohio
Welcome. I added the adjustable clevis to the stock Imperial kickdown, but other than that, it's stock 4 bbl linkage from an E-58 Gran Fury.
