brotherGood
Alright, ever since I swapped engines, I've had a slight miss at high rpm. While the engine isnt stock, I wouldnt have initially thought it was enough to require a bigger coil. Currently, im running a 318 LA block, with magnum heads that have had a valve job done. Im using shim gaskets, have a summit 6900 cam and summit 600 carb.
It has a new distributor with the rebuild, and we added a new pcm, cap/rotor/wires as well. I've been reading the factory coil may not put out what is required when you start really modifying it, and I wasnt sure if that's my issue.
Thanks
Thanks
