bremereric
FMJ Body Moderator
I was thinking about this for some time....stock clutch and pressure plate or more performance clutch and pressure plate...for the same amount of clutch pedal pressure I chose the following....next paycheck on the 15th and it will be on it's way...the best price between Summit and Mancini was Mancini racing...that's a first...
Product Description
The Centerforce Dual-Friction clutch set is a performance matched pressure plate & disc combination. Centerforce Dual-Friction pressure plates feature their patented centrifugal weight system (where applicable) and specialized machining processes to provide a performance clutch that offers exceptional street characteristics, while offering outstanding holding-capacity and durability. Furthermore, the Centerforce Dual-Friction disc has a full facing on the pressure plate side for drivability and longevity, while a carbon composite puc style (segmented) facing is used on the flywheel side for a positive engagement and increased holding-capacity. Dual Friction is engineered for those who are looking for the ultimate in street/strip holding power and performance without sacrificing pedal effort and driver control. While the Dual Friction has been engineered primarily as a street clutch it can be used in mild competition applications.
Centerforce Dual Friction Clutches
Clutch Kit, Dual Friction, 1 in. Diameter Shaft, 23-Spline, 10.4 in. Diameter Disc, 1974-74 DODGE/PLYM CARS
$359.95
CTFDF269739
Product Description
$359.95
CTFDF269739
