Imperial conversion questions
Bryan M.
Kentucky
1. Can someone get me good pics of the fuel flow meter installed? I know it's near the carb, and that's about it.
2. On the fuel tank, the factory wiring has two connectors: blue/purple/gray for the main connector and a green for the fuel pump, I believe. What do I do with the green wire?
83Imp
Jacksonville, NC
Bryan - plumb the fuel lines I sent up from the mechanical pump area. The lines go behind the AC/Alt brackets, close to the block (of course). They only fit one way. That should allow you to see where the flow meter bolts down. Here's a link that shows the factory retrofit too:
http://www.imperialclub.com/Repair/Year/1981-1983/Retrofit/Page22.jpg
As far as the wire to the pump - other than just taping it back safely, see if it even has 12V since you removed the ASDM. I'd just tape it out of the way.
Brad
