WANTED kickdown linkage
volare 1977
I have a kick down linkage set up but it isn`t off a volare aspen. I believe it is off a 74 charger. Which is different I believe.
volare 1977
pic
To the original poster, are you looking for a 2-bbl or 4-bbl setup – for I didn’t seen that mentioned anywhere.
The picture above is a 1-piece kickdown linkage and it might not work in an A-body.
A and FMJ-bodies have about the same space between engine and firewall. Every once in a blue moon, a 1-piece kickdown linkage will fit and work in an A (or F) body – but the other 30 times it hit the firewall and won’t allow throttle to open fully.
65 cuda
arizona
4 barrel and i need linkage from carb to floor shift 904 transmission instead of column shift
