Leaking exhaust threads
88_AHB
West coast
Hey everyone,
Wondering if any of you have come across this issue.I recently fired up my rebuilt 318 and the front and rear exhaust (header) bolts were leaking coolant from around the threads? I wasn't aware that dodge runs these into the water jackets? I'm gonna pull all 4 or 8 bolts out tomorrow and either use thread sealant or rtv. Is this a common occurrence or is there something wrong?This is my first dodge,i've have been a GM for a long time and never had this issue with them.
Thanks everyone, never have seen something like this happen. I’ll give it a go later today.
Be careful to not overtorque those fasteners. If they break, after they are locked in there, you'll be extremely irate at all the trouble that mistake is gonna cause.
If I have to remove those corner studs to install the headers, I always put the studs back in there, with no sealer. I double-nut the buggers, torque them in there against their shoulders,and remove the nuts.Then I put a drop or two of thread locker on the shoulder right next to the head and let it wick in. Finally, I use the slanty conical washers and usually brass nuts. I doubt anyone could ever overtighten those brass nuts to break the studs,lol.
On one occasion I slotted the rearmost holes down thru the flanges, because I was afraid getting the studs out would be impossible without breaking them. Those special slanty washers came to the rescue, and bridged the slots.
Some say those brass nuts come loose by themselves.
I say; get a better gasket.
The gaskets that came with my TTIs were fabulous. Nothing ever came loose. After about 5 or 6 reuses, they finally wore out. I cannot recall what brand I replaced them with, but they must be good,cuz they've been on my 367 since 2004,IIRC. I remember I got them from Jegs, not house-brand tho.
Curious what’s the advantage or disadvantages of using a stud vs bolt for the 4 corners?
The stud seals better against antifreeze leakage than a bolt because of the shoulder. If the stud makes it hard to install the headers then either cut them a little shorter or leave them out until you get the header in place. I like the studs because it helps with keeping the gasket in place when installing headers and a place to hang the headers while trying to install the rest of the bolts. The problem with stock heads is many times the studs are rusted in place and can be a bear to get out without damage.
On my big blocks I've been able to retain all the studs with the exception of two on each side do to length and interference with the headers. I much prefer the studs over bolts.
I put all bolts in and used the high temp sealant. No leaks so far... Perhaps I should switch out for studs instead now to make sure I’m good for later.
Only the four end holes on a small block have coolant. As long as the bolts don`t loosen you should be ok.
I know this now, just meant i'm second guessing on those 4 with bolts in instead of studs lol!
