jasperjacko
- Joined
- Dec 4, 2011
- Messages
- 1,672
- Reaction score
- 251
So here's the deal. Charging the a/c in Modoba. Afterwards, idling in drive, car shuts off just like the ignition is turned off. Started right back up and then shuts off when I release the ignition switch from start to on. Any Ideas? Next question is heater/a/c control related. I can't change blower outlet from heat to vent to defrost. It stays mixed between defrost and heat. Also, the vacuum operated water valve doesn't opererate with the heater controls. The diaphragm works with hand vac pump but I get no vac. from the gray vac line that goes to it, reguardless of where the temp is set to. Thanks for your input.
