Aspen79
- Joined
- Oct 3, 2014
- Messages
- 42
- Reaction score
- 5
With this cam have a noticeable idle?
Camshaft spec
int lift at valve .488
ext lift at valve .510
duration .050 int 234 ext 244
Lobe seperation 112
edelbrock camshaft part # 7177
It's a street car but I want somewhat of a rough idleNot sure what you mean by noticeable idle.
Ok and plus I plan to run open headersI think anything over .047 duration has a nice rough idle. so .050 should sound mean
That is a chevy lobbed cam. Cam card says 10" of vacuum. Good luck with that with power brakes. It will probably get you the sound you want. Match the cam to your combo. You'll be a lot happier with the performance, not sound of your car. Much better grinds out there. Look at Comp, Lunati, Hughes, Howards, or just go custom grind. I wouldnt use that cam for anything other than a door stop.
What are your engine specs, what transmission, rear gear, and how honestly are you going to use the car?
In the Aspen, I was running the MP761 Cam. Not a match for the combo I had at the time, sounded like a tiger, real lopey, sound wasnt what I was going for. It needed more compression and gear. I was running magnum heads so the rocker ratio was 1.6 and that raised the lift on the MP761 to .480/.485. Over cammed it IMO. In hindsight I would have went with a Comp Cams XE262 or Lunati Voodoo 256/262. But my days messing with flat tappet cams is over. All hydraulic roller for me now.
MP761 Specs
Adv. Duration: 268°/272°
Dur. @ .050'': 228°/231°
Lift: .450''/.455''
Centerline: 110°
Overlap: 50 degrees
Match the cam to your combo and how your going to use the car. You be happier with the results. Sound is nothing if it's a dog.
360 .030 over stock stroke, edelbrock 63 cc RPM heads and intake. Pocket ported and intake matched.MSD ignition system.
727 tranny (rebuild)
4.10:1 gear
it going to be a street car I drive on the weekend and
to car meets. I plan on street racing and maybe a little track time too
Do you have a video of the car idling I would LOVE to hear it
Yeah so my cam is slightly bigger that the one you ran. I also have 10.7:1 CR
So you feel that I could do better on the cam choice?That mopar cam has a more aggressive ramp rate. Take advantage of the .904 mopar lifter.
