moparman_76
i have a set of heads for a small block and where the x or the j would be there is an o. does anyone know what these heads were used on any help would be appreciated thanks
so if there a 340 T/A heads does that mean they can only be used on a ta block cause of the moved push rod holes?There are engines that have had an X and J or any variation of those letters straight form the factory over the years.
I prefer to use the 894 X heads with another X. Any of the 915s with letters X O U J N will work together as long as valve sizing is the same. Not a lot of difference between any of those early LA 340 heads.
An O head should be a 915 casting. That head would have been used on 1970-1972 340 and 360 engines.
The 915 casting was also used as the head for 340 T/A engines which adds to the fun with uninformed sellers, moved pushrod holes.
