Moparguy45
I have several things for sale that i no longer need or want and could use the money to fund my project. If you are interested send me a pm. Thanks for looking
Mancini Racing distributor - $150
This is the discription by mancini racing:
A high performance unit, ruggedly built for all small block Mopar and 392 Chrysler engines. Improves on stock. Built-in 50,000 volt coil, premium cap with brass terminals, micro polished die-cast housing, both upper and lower bushings for added durability, and no voltage reducing ballast resistor. Fits B & E Body Cars - A Body may require modifications.
This is the link http://chucker54.stores.yahoo.net/maenheidi2.html
Edelbrock performer rpm intake - $150
Nothing is wrong with it and it is not modified in any way.
Mopar "J" Heads - $350
I have just had them milled .010 now the chambers are 70cc. They have comp cams valve springs with the spring heights all set and can handle up to a .490 lift cam. They have 2.02 intake valves and 1.60 exhaust. they have brand new HD valve stem seals. they have not been bolted on since they have been milled. they have not been ported. they are ready to just bolt on and paint. i also have the mopar performance cam that the heads were set up for that i would sell as a packaged deal for $400. The cam has never been installed and comes in the original mopar box with the lifters and the lube.
BRAND NEW Kieth black Pistons and rods - $350
i have a set of kieth black 107 pistons and connecting rods for sale. the pistons are for a standard bore 360 mopar. The connecting rods are 496 which from what i was told are the strongest factory connecting rods made and were used in 340 T/A engines. The rods have been reconditioned. The pistons have never been installed and have brand new hasting rings on them. i just paided $318 for the pistons and rings
