Erics5th
I installed some poly sway bar bushings by Energy Suspension on the front 1 1/8" sway bar on my '84 5th, replacing the rubber bracket bushings and the bar bushings. The end links where already poly's. The kit for this is 5.5111. R at the end is for red color, which is what I used. The only problem I experienced is the bolts supplied for the end links where to short. They are 2" in the kit. I used a 2.5" bolt and one retainer on each side so that the bolt would not hit the torsion bar isolator on the lower control arm and so that whey fit properly. Cost was around $36 plus shipping from ebay.
The kit:
Sway bar bushing and bottom mount bushing:
End link:
Top bushing:
Very happy with the results. Hope this helps anybody wanting to do the same to their F/M/J.
The kit:
End link:
Top bushing:
