mopops
have slight exhaust popping at idle only ,no miss off idle or under load. timing set. any ideas ? i need something to do for the week end tks gjg
			Might do the trick! I've used that at work for things like cold start misfire or hard cold start where the carbon soaks up the fuel until it's saturated on port injected engines, and basic crappy running when carbon fouls up the air flow into the chamber on direct injected engines. It does wonders in a lot of cases. It'll smoke out a 10 square block area in the process but, what are you going to do?looks like a BG combustion treatments in order tksgjg
