Power booster pushrod length.
Infiniti Dave
Aurora,Ohio
Has anyone attempted to adjust the power booster pushrod to master cylinder length on a 79 "F Body" ? I can't find any specs in the appropriate service manual and most of the posts seem to have a lot of guess work. Any procedures and spec is appreciated!!
AMC Diplomat
NY
You need a gauge to make it easy. Everyone carries them.
You adjust it so it doesn't press the plunger but it's about to.
You shouldn't have to adjust it at all unless you're mixing parts.
Infiniti Dave
Aurora,Ohio
Found out after I bought the car that the brakes wouldn't release after driving several miles. Someone before me either mismatched parts or played with that depth. Unfortunately my time at a Dodge Dealer years ago always said "don't ever mess with that". Now I'm in uncharted waters for me. Thanks to all for the sound advise. The tool is ordered and we'll see soon.
You can feel if it's touching or pushing the rod when you put the master cylinder on. Put it in place but don't put the nuts on. If there is any resistance before the flanges sit flat on the brake booster the rod is too long.
The tool looks simple to use, I saw they're cheap on Amazon.
AMC Diplomat
NY
It's one of those silly tools you'll use once every few years, if that. It made my booster replacement really easy. All it did was confirm the booster pushrod was perfect out of the box.
If your brakes aren't releasing, I'd suspect old swollen brake hoses before I would think to check booster pushrod length.
Mike is right though, if you have to bolt it down to get the master cylinder to sit flush against the booster, then that push rod is too long
Infiniti Dave
Aurora,Ohio
Got new lines and hoses, so if that's the issue it'll get repaired during the process. The only concern is that when the brakes wouldn't release, I got it home by cracking a line at the master cylinder to release the pressure. Not sure a restricted hose would respond that way . Thanks !!
I would suspect the master piston is not all the way released just enough to block the compensation ports, and holding some pressure in the system. With the brakes dragging, the fluid heats up and expands, but can't return to the reservoir. Then the brakes drag more and more.
Never ran into it on a Mopar, but did on other makes at work. Toyota seemed to be the leader. From what I understand, the plate in the booster gets bent out over time, and reduces the pushrod depth. Ended up replacing the booster on those to solve the problem. Most weren't adjustable btw.
8T2TOP
Phoenix
They have a common problem with proportioning valve under MC...
AMC Diplomat
NY
You're 100% right, those later proportioning valves aren't brass, they're some kind of iron and they can rust on the inside
