Power brake modification is a bit weak
Stonekij31
indianapolis
I successfully installed a power brake booster on my 79 Volare with the correct linkage. Bled the system correctly and the brakes feel quite loose. The car will stop, but I have to put the pedal to the floor. Any suggestions?
AMC Diplomat
NY
Did you bench bleed the master cylinder before installing it?
