Production Numbet for E58 powered 1980 Cordoba Ls
tim berry
boston area
I've haven't been on this page in quite some time . Life got in the way .
After bouncing around other sights I have been told that only 17 of these cars were built .
Today I came across this information .
I still own the car and am planning on some up grades , 408 , 8.75 , caltracs, paint ,interior.
If I get time, I will check to see if those numbers are correct. Past experience has told me that those numbers are cars sold in the U.S. only and are NOT production. But, as I said, I will check.
Just installed F body Cal track split mono leaf springs and bars on my Cordoba last week. I selected the b body shock plates for for more shock options. I also installed an m body rear sway bar however I need to find either e body upper spring Plates or fabricate a set to connect the end links.
Mines not an original 360 car however I have a .60 over 360 with magnum heads 1.5 compression pistons, Holley EFI, and and M1 intake.
Hey Slodoba I just saw your reply.
How well does the caltac suspension work and are you happy with it
Sorry fo the late reply.it works much better than the sloppy stock isomount setup and weak springs but hav only had the car out once. The 904 trans finally gave out
