Quadrajet questions
rustytoolss
N.E. Ohio
During the years mopar installed Quadrajets ( the ones with out any electronics) on FMJ cars. Does anyone know what CFM they were, where the 318 different CFM, that the 360 CFM ? Does any one know what the throttle bore sizes were ? part numbers ? Thinking of installing a QJet for mileage. I do have a TQ, but it has fuel leakage issues. I have never had those kind issues with a QJet.
There was only 1 non-feedback Q-Jet used on cars, which were the export models from '85 and '86. Rochester carb number was 17085411.
CFM on the QJet was a little bit under the small TQ, about 750 CFM.
You'll probably have a hard time finding the 5411. I'd recommend considering a 17085408, or 7175. These were light-duty 360 Q-jets that should be ok on a 318 with the J-head 587 or 345 casting that the M-body Pursuits used.
If you can't find those (the 5408 was probably the most popular, outside the E4ME 17085433 used in the squads), look for a 17085432 or 17087175. You may have to rejet the latter two, but in my experience, they should be just fine.
Try to find an AC Delco rebuild kit, if possible. Don't forget the little filter inside the fuel inlet.
I had very good luck with the Q-Jet on the 318 and 360. They're easy to build and tune, they hold their tune longer than the TQ, and the choke set-up is much better in the winter. That said, the TQ performs better, and are happy tuned as lean as you dare.
Ball park idea of fuel mileage with quadrajet over stock carter 2 barrel BBD...thanks for the information
The TQ might give you decent mileage. The Quadrajet uses a little more fuel in my experience. Not a significant difference in town. On the road, with everything else being relatively equal, maybe 1-2 mpg less than the TQ. You can tune the QJet leaner, but it won't be happy. I never bothered. The Q-Jet has much better drivability when set up right.
For the best mileage, a properly tuned '85+ Lean Burn/Feedback system can't be beat. No two ways about it. If you want to run regular electronic ignition, look for a 2280 Holley, which is the non-feedback version of the BBD used after 1984 in pickups and export cars. Make absolutely sure your timing is dialed in - figure 7 -9° BTDC base, and at least 50-60° BTDC, all in, at 4000 RPM.
The preferred numbers have been described, but the following lists the Quadrajet part numbers, used by Chrysler after the Thermo-Quad was discontinued, with both electronic feedback and non-feedback versions.
Rochester Quadrajet Listing
Carter ceased production of the Thermo-Quad after the 1984 model year. Chrysler switched to the Rochester Quadrajet M4ME and E4ME for 1985-1989.
  • M4ME = "Modified" (post 1974), 4 barrel Quadrajet, electric choke, non feedback.
  • E4ME = Electronic feedback, 4 barrel Quadrajet, electric choke.
Following is a listing of these carburetors for reference.
NOTE: The identification number is stamped vertically on the left side near the secondary throttle lever.
Rochester Number
Application
Chrysler Number
Details
17085407
85 318
4306407
O2 E4ME; Service #4342805
17085408
85-87 360 Truck
4306408
AT Fed; Service #4342806
17085409
  1. 85 318
  2. 85-87 360 Truck
4306409
  1. Fed O2 E4ME; Service #4397609
  2. AT Fed HA O2 E4ME; Service #4342807
17085411
85-87 318
4306411
Can Exp; Service #4342808
17085414
85-88 360 Truck
4306414
HD
17085415
85 360 Truck
4306415
Fed CA Can HD; Service #4342810
17085416
85-88 360 Truck
4306416
LD, Fed, CA, Can
17085417
85-87 360 Truck
4306417
MT Fed; Service #4342914
17085425
86-88 360 Truck
4306425
Fed; Service #4443060
17085431
86-88 360 Truck
4306431
HD CA Can; Service #4342932
17085432
86-88 360 Truck
4306432
HD
17085433
86-89 318
4306433
O2 Fed CA Can E4ME; Service #4397609
17085434
86-87 360 Truck
4306434
AT Fed CA Can; Service #4443060
17087175
88 360 Truck
4306419
AT, Fed
17087176
88 360 Truck
4306420
MT, Fed
17087177
88 360 Truck
4306424
AT, Fed, HA
17087245
88 360 Truck
4306437
Fed, CA, HD
Table Abbreviations:
  • AT = Automatic Transmission
  • MT = Manual Transmission ( No reference means both transmissions )
  • CA = California application; generic for CA, Sales code N95
  • Fed = Federal application ( No reference means both Federal and California.)
  • Can = Canada application. Typically, Canada used Federal carburetors except as noted.
  • Exp = Export
  • HD = Heavy Duty Cycle
  • HA = High Altitude
  • O2 = Feedback unit
Rochester Number
Application
Chrysler Number
Details
17085407
85 318
4306407
17085408
85-87 360 Truck
4306408
17085409
  1. 85 318
  2. 85-87 360 Truck
4306409
17085411
85-87 318
4306411
17085414
85-88 360 Truck
4306414
HD
17085415
85 360 Truck
4306415
17085416
85-88 360 Truck
4306416
LD, Fed, CA, Can
17085417
85-87 360 Truck
4306417
17085425
86-88 360 Truck
4306425
17085431
86-88 360 Truck
4306431
17085432
86-88 360 Truck
4306432
HD
17085433
86-89 318
4306433
17085434
86-87 360 Truck
4306434
17087175
88 360 Truck
4306419
AT, Fed
17087176
88 360 Truck
4306420
MT, Fed
17087177
88 360 Truck
4306424
AT, Fed, HA
17087245
88 360 Truck
4306437
Fed, CA, HD
  • Exp = Export
Thanks for all the information, and the added web pages !! :)
650cfm. Nw if you wanna get away from all that electronic stuff, then just pull the bottom plate off a put it under a Chevy Quadra-jet.
I have a number Mopar Quads in my cache
of 200 Carbs.
They are popular and preferred by many
Superstock Mopar racers.
