Radio Delete RR or RT?
XfbodyX
Central US
Has anyone ever seen a radio delete F RR or RT?
Im looking for a radio delete 76-77 F plate, they do exist, I lost a really good one. You can tell the early 76 77 F because they have the horizonal line pattern that matches the pattern on the dash bezel that has areas blocked off.
It bolts to the radio hole using the radio pattern.
There are many around that are smooth but not of the texture I mentioned.
marty mopar
Tempe AZ
I have a radio delete dash bezel /woodgrain NOS for 1976-78 F Bodies
#3593732
this is for an A/C equipped car
I do not have the actual radio delete plate
TonyVolare
NJ
they have them at Walmart for $15 for aftermarket radios just don't pop out the center piece and you are set. If you want a radio you can pop out the precuts for 1 din or 1.5 din.
