FOR SALE Rare Rear Defogger setup 78-79 F-Body
DCAspen
ct.
Rare 78-79 Rear Defogger setup ,Dash Bezel w/all switches,Blower motor and wire harness in excellent condition. $75.00 or BO+ shipping
Yes,I do have the 1980 only switch plate.
Super rare to have a blower setup in a 1980,Hi,LO OFF for a Defogger setup,OFF/ON for a Defroster setup
Selling the complete blower setup,If you need the 80 piece,I'll swap it for the 78-79 dash piece.
Where are you based out of (state), and would you go lower on price? I just turned 18, and have a minimum wage job.
In Connecticut,If you have a defroster,why do you want a defogger?Is it not working?I have the wiring harness for the blower setup,Should plug right in just like the Chrysler did it...Plug & Play.
Does the defogger blow just cold air (from the trunk) or does it have a heating element in it?
Assume that there would be a cutout in the package tray deck metal for it?
Blows air onto the back window,yes there is a cutout in the package tray
The blower motor does not heat the air, per se. Air movement is what it uses to clear the “fog” away, using cabin air.
The heated glass design uses electric heating grids on glass to do the same thing (remove fog) - but also removes “frost”, snow and ice, as well.
I have had cars with both designs. The blower design is great to retrofit to a car without either system.
If you currently have a defroster system (glass grid), it might be best to find out what is wrong with and fix it.
DCAspen,
Do you have a faceplate with defroster and rear wipers?
Bud,Rear wipers are a seperate switch that mounts in the lower dash panel to the right next to the pass side mirror control,Yes I have one.
