Rear brass brake fitting for 8.25
prowler
santa clara CA
Things are almost through with my 7.25 swap to 8.25. I am detailing the rear brake lines but have hit a snag. The brass brake line block that's bolted to to top of the axle housing has two threaded holes for the left/right brake lines. There is an additional fitting/line that's coming from the master cyl. The line, I thought was a threaded hole that the line bolts into is NOT. It appears to be factory brass welded to the block with the line attached to the block. Problem is, the line was cut right at the brass fitting so it's useless. Can't find a part number for that block w/hose. Anyone else dealt with this issue?? It appears to be an assembly,..... line and block as a unit. Thanks
Rear brake hose, it's a common part. There are 5 options for all the same part for $20 or less on Rock Auto. Makes no difference what axle it is.
Update on the brake hose. After cruising through ebay, I found the exact hose made by Dorman. $28.00,... and on the way !!
