Rear end tag deciphering
rcmaniac791
Ok, so I recently serviced the rear end in the 5th (7 1/4 w/ 2.26 gear) and while I'm unimpressed with the gear ratio, I noticed 2 tags on the rear end. I expected one of them there for the gear ratio, but I wasn't expecting 2. I'll post the pics below. Looks like one of them says 2.2 (probably for the gear ratio) and the other looks to say 0274. Not sure what that's for.
I should also mention that the gears looks factory fresh in this thing which I'm happy about
Yes, the 2.2 is for 2.26 gears. The other tag,,,,,,,,,,,,,,,,possibly a date code? They're usually 4 digits anyways.
DCAspen
ct.
0274 date code.27th day of 1984.a 3 digit date code,the 1st 2 digits would be the week of manufacture.
rcmaniac791
That makes sense. The DOM for the car is February of 1984, so that fits perfectly.
Glad to see you are changing the fluid in your diff! It is often overlooked.
It only holds 2.2 pint (1.1 US Quart) of fluid so any leaks can wipe out the bearings in no time.
rcmaniac791
The fluid was changed when I first got the car in 2013, but that was almost 30,000 miles ago, and I wanted to inspect the rear since the 7 1/4 is not known to be the strongest axle. I do like to keep things well-maintained! The shop that did the work originally lathered on the RTV for the diff cover. I used a gasket so it took longer getting all the RTV off than it did anything else!
