Safe front end jack point?
JBFury
Ohio
Front of car, before the oil pan. Seems to be part of the frame, but I'd rather be safe and check.
Yes if you are jacking whole front at once. You can also use where the frame comes to a T behind the front wheels if you are doing one side at a time or the spare tire jack points on the rocker panel if you are using one of those small hydraulic jacks.
