WANTED Set of leaf springs
Ok. I will keep that in mind. Have a line on one or two pairs as of this morning. Thanks!
Early Dodge Dakotas have leaf springs with same front segment length, rear is only 2" shorter. Rear bracket can be slid forward that much with a home made plate adapter, HOWTO is in some of the older posts on line under Bill55AZ.
3 Dakota leafs from the right load rated Dakota will do the trick. Option is to use an FMJ main leaf on original brackets and the other leafs from a Dakota.
